Vy commodore
Aidan2611
ACT
Vy commodore
Hey guys just wondering if anyone knows something about something.
My partners VY is leaking coolent but it usally starts leaking a little bit after a whole day after it ran it doesnt leak straight away....
So confused
the_boozer
no more VK
51
Shitsville Morwell
hilux
start with a new radiator cap
krusing
Melbourne, Bayside
Could be leaking from -
Radiator Hose
Heater pipe manifold seals [in the front of the engine]
Heater Hose
Heater Tap
Heater Core
Radiator
Radiator Cap [as previously mentioned]
LIM gaskets
Head gasket [unlikely, but not impossible]
That's a starting point to look at
The best thing is to lay a drop sheet on the ground and park the car over it,
That will give you an rough indication the where its leaking from, then go searching,
If you don't have any anti-freeze/anit-boil in it,
put some in there to colour the water, that way when it does leak, it will leave a trail of water, and also see it on the drop sheet.
Tonner Matt
Darwin
VZ 1 Tonner LS1 M6
Pressure test the cooling system
Aidan2611
ACT
Vy commodore
Ive gone through it and noticed its dripping doen past the sump but i habent driven it for a couple days now and randomly started leaking this morning doesnt seem like the hoses or radiator cap as i only put a new one on the other day
losh1971
North Tas
VE Series I SS Ute
Needs pics
Aidan2611
ACT
Vy commodore
New cap and hoses are all good seems to be leaking past the sump.
losh1971
North Tas
VE Series I SS Ute
Without pics it will me extremely hard to say where its coming from.
markalan1two
Smile and wave boys !!!!
52
NSW
X5 BMW, GenF2 GTS, HSV Y R8, AMG C43
v6 v8? where past the sump front? back? side? may be welsh plug if its not coming for the top
Tonner Matt
Darwin
VZ 1 Tonner LS1 M6
It's quite possible that it's the tell tail from the water pump...…..it could also be leaking from somewhere else such as a welch plug as was suggested above
Trying to get lucky and guess the issue is just a waste of time and your money
If you get the cooling system pressure tested, it'll identify exactly where the leak is, and then you can fix it yourself or have it fixed without chucking multiple random parts and dollars at it in the hope of getting lucky
