fugly59
fugly59
- Jun 20, 2016
- 8
- 0
- 1
- Location
- Berkeley Vale
- VY Executive S1
This was exactly the post that I needed answered. Until the slanging match started
I have a VY V6 with pretty much exactly the same problem.
The main difference here is that it only appeared after I replaced the inlet manifold gasket.
I have temporarily 'cured' the problem by disconnecting the MAF sensor. It runs absolutely perfectly except for 'maybe' that it idles a fraction higher. It also has the obligatory 'Check Engine' sign on the dash.
I actually purchased a brand new MAF sensor thinking that this would fix the problem. Unfortunately, it runs exactly the same with the new unit connected. I am only running the vehicle to & from work at the moment (20 minutes each way) as I don't want to drive it too far without it running properly.
I have also removed the throttle body assembly again. Cleaned it again. Took out the idle control unit. It was a bit dirty so I thought I'd found the culprit. Both hoses were connected onto the bottom. Still no difference. Looking at the tacho, it seems to stall when the transmission changes but only while coasting down a hill or into a corner.
I am thinking that maybe 1 of the 3 hoses connected to the end of the 'plenum' (is that correct?) may be the culprit. I am confident with the brake booster hose but not the other 2. I don't even know what they do.
If anyone has any answers or suggestions, I'd like to hear them.
Thank You
Thank You
