calay
- Jul 5, 2009
- 119
- 0
- 0
- VZ Calais
so, from reading thru about 10 pages of the same stuff over and over, my conclusions...
for the utes... even tho the tank is 70L, there is about 15L of UN-USABLE fuel due to the design/pick-up location, so don't think you can use all of the fuel, when the gauge says its empty the car is very close to stopping...
i couldn't determine whether this was a problem on the sedans also. my calais does wierd things below half-full, but that is mainly when i'm in my driveway which slopes up.
this has led me to the conclusion that the pick-up is towards the front of the tank, which is useless since you're more likely to be in a world of **** if you run out of fuel going UP a hill rather than down one...
looking at my tank, its not surprising there are so many problems - it is so big and flat that you could spread out 5L on the base of it and not even be 1cm high!
sounds like you need to get in there and move the pick-up closer to the base of the tank
i'm going to throw a jerry into the boot then see how far i can go before running it dry to see if my tank is the same as the ute's
