weird electrical issue leaves car dead
TonyJZX
East Coast
Commodore M6
ok have the weirdest issue
i put in a new hot and cold relay (fixed my overheat issues)
since then i've had this issue where the car ends up having no electrical power after turning the car off but I doubt the issues are related
so basically you go home from work and the car is dead stick in the car park
car does not start but clicks, dash lights up and then everything dies
now you can do a jump start and it goes
but i replaced the battery anyway and it still does it every so often
however i found that you can pull the terminal and put it back on and then it fires up as if there's nothing wrong!
dash say 13.8v so everything is good
what's the go? earth? ecu?
its an LS1 manual btw.
obd2 says everything is fine
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Bad earth or battery clamps need a good clean.
wrx884
WA's ASR Rep
39
VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
wen u say the dash read 13.8V is this while the car is running on idle? it should b above 14V but still thats not 2 bad which makes me wonder wat about wen all accessories is on so the system is under alot of load? put everything on that u can find that needs power, crank the stero also and measure. if it drops below 13V it could well just b ur regulator not charging the battery enough so could b on its way out. u should b looking at least 13V, more so 13.5V under heavy load.
Do u have a multimeter? somtimes the dash read out can vary slightly.
TonyJZX
East Coast
Commodore M6
i have pretty much no accessories in this car... just a plain single deck + speakers... i'm not into audio
this is the thing... if the car fires, it FIRES
ie. dash says the volts are fine before it starts and it goes
but if it dies you get no electrics at all
its just annoying to pop the bonnet and reseat the terminals to get it to fire
i'll clean the terminals... there was some corrossion but i changed it at 5.15pm after buying a battery at Repco.
wrx884
WA's ASR Rep
39
doesnt matter still crank the stereo, the louder u have it, obviosuly it will still b trying 2 take power from ur alternator. Put lights, hi beams hazards, aircon, demisters anything u can think of wack it on and test (these r called accessories). Even do the test with the car off, it'll show how many volts its trying 2 pull.
u said it still clicks, 2 me seems like a dying battery as the starter is still trying 2 kick it over but doesnt have enough volts 2 do so. ur battery mayb good but it could b ur regulator thats not charging it.
still do the checks and report it'll help us help u.
TonyJZX
East Coast
Commodore M6
nah it clicks once then goes complelely dead no power, no nothing
all dash lights off, radio gets reset, can't run the electric windows, as if battery is disconnected
reset terminal, its back to normal
something real odd is going on
wrx884
WA's ASR Rep
39
ahh clicks was misleading haha sorry man ignore wat i suggested then.
can u determain where the click is comming from? is it a relay click or other? had a similar thing happen 2 the misus old gemini but i doubt it would b the same haha turned out 2 b a fault ignition switch behind the barrel. (havent heard of these fail really i dont think).
mayb its got somthing 2 do with the relay u replaced? is it the right part ect...? wat does this do exactly?
TonyJZX
East Coast
Commodore M6
this car has a ####ed barrel (ie. the key pulls straight out when the car is running)
the low and high speed fan relays i replaced because they weren't kicking in so the local spark shop said just replace thing because its a cheap fix... the car would go over 110% on a hot day but since i'm lazy i didn't fix them for ages since this car has good cooling
could be either/both who knows
lout
60
Langwarrin Victoria
sounds like faulty battery cables/connections
Aussievtv8
47
Werribee
Vt ss HOLDEN 304
As mentioned, check earthing/alternator
