Any reason youre using twice the weight of the recommended oil?
After reseraching this topic for some time, reading the following information on another forum, posted by the owner of mainlube oil, swayed me in the direction of Castrol Edge 10w60
I appreciate the fact that you guys have spoken to many shops however, as an advanced trade automotive engineer my self I can tell you there is jack training about oils in an apprenticeship, you have to learn most of this **** yourself.
I have been fortunate enough to play in this field for 30 years. (apart from owning an oil company and advising how to run some of the largest and most powerful machinery in the world)
The key factor here is film strength, this is what keeps your load bearing surfaces from touching. The higher the viscosity the better the film strength the less the wear.
Now there is a extremely small trade off with resistance to flow however, its barley measurable, also a good high tech Synthetic will reduce any drag from a higher viscosity with a superior slippery additive package when combined with higher viscosity it isn't hard to double the machines life.
Now just to squash a few myths about oil like 10w60 being too thick, see the facts below.
And by the way, you asked what is the best, without a doubt, Mainlube is, its just bloody expensive. (funny that!)
10w60 MUST give better protection than 10w40 provided the additive packages and base oils are similar. Synthetics will give better protection as their base oils naturally have a higher V.I. (viscosity Index) additives can also be added to boost the V.I. The higher the V.I. the less the oil thins when heated the better film strength and hence less wear.
Everyone puts so much attention on the viscosity @ 40C (quoted on the packaging) have a look at viscosity @ 100C, (from the spec) this is the temperature your oil is at 99.5% of the time.
0w30 is around ISO 10 @ 100C (SAE 3) approx. (very much like penetrating oil)
15w40 is around ISO 14 @ 100C (SAE 4) approx.
20w50 is around ISO 18 @ 100C (SAE 6) approx.
10w60 is around ISO 22 @ 100C (SAE 8) approx.
Sowing machine oil is around SAE 7 @ 40C to give you some comparison on just how thin your engine oil is @ 100C.
So as you can see, there's not much difference @ 100C (running temp) between the oils.
The thicker the oil @ 100C the better film strength (layer of oil keeping the load bearing surfaces apart, reducing noise and wear)
And of course any kind of noise (other than combustion knock) has to and must be different stages of very slight metal to metal contact. (hence different stages of wear)
Within 30 seconds from a cold start up your engine oil would've warmed up at least 10 to 20C above it's starting temperature so the oil is not at the starting temp for very long.
So change your oil at 1000klms from new (don't forget to flush) then change straight to a Synthetic 10w60 and do the best for your engine.
To do better run 1 or even 2 FilterMags on your oil filter, 2 will ensure all oil going into your engine passes over a rare earth magnet, this will remove ferrous metal that can be small enough to fit through your paper element oil filter yet still be large enough to damage load bearing surfaces as they're forced through by the oil flow. This can cause even more damage if your engine is modified applying extra load.
