What Steel Braided Brake Lines to Buy?
daves8
44
2015 VF Calais V 6.0 | 2013 VF Calais V V6 Wagon
I think he means when you put the rotors and pads on.
I have no issues with my car as is, just want firmer pedal feel.
System was bled properly
eman1
newcastle
VF2 Redline
Id say 1 hours for a competent mechanic, I did it in backyard with jack stands in 2 including the brake flush. Just ensure it’s a quick change over as the issue with abs would be if you let air in the lines and it gets all the way to the abs module which requires a tool to cycle it to get air out. (Extremely rare)
Banjo79
VF SS Sportwagon
The mech that did mine let air into the abs module, but having said that, the safebrake line also failed mysteriously at install and I had to oraganise a local knock up. Good times!
dassaur
VF Calais V V8 Wagon
To add to the knowledge base. I recently did all 4 to stainless lines using HEL.
First time changing lines, wasn't too hard.
Once undone, have to grind off front 2 stock brake hoses from the metal bracket, then pop the HEL ones in and use a retainer like the rears. Mine didnt fit so had to file a bit, then it was no problem.
Once lines changed, I bled brakes normally.
Then did ABS brake bleed, and a decent amount of air came out.
Definite difference in pedal feel
KING46Calais V
2017 VFII Calais V 6.2L Sed
What did you grind off?
I can't image to replace a brake hose, you would be required to grind the old one off.
dassaur
You need to, unless you get a hose with the bracket included.
In the pic below you will see the stock lines. The line is moulded into the bracket. To re use the bracket, you need to grind the top part of the hose off, then punch the bottom out.
KING46Calais V
You need to, unless you get a hose with the bracket inIn the pic below you will see the stock lines. The line is moulded into the bracket. To re use the bracket, you need to grind the top part of the hose off, then punch the bottom out.
Ahhhhh.ok
Didn't know you had to punch them out.
scaredyet
Mosman
Holden VZ Lumina Wagon
Do the braided lines from safebrake fit the rear of a wagon. I enquired once before and someone said the don't fit
