What Type Of Diff Do I Have????
brocksta05
37
somewhere NSW
2000 VT S2 Acclaim
My car is a 2000 model VT series 2 acclaim v6 n/a Auto and I am trying to work out what LSD diff I can use in it. Its currently the original single pegger 3.07:1 ratio with the round flange yoke on it not the rubber donut crap. Is my diff centre a BW-78 or a BW-80??
A list of which model commodores I can get one from that will bolt straight in would be absolutely awesome!!
Cashman_309
VTII Calais
BW-78, single pegger.
Edit: any vt-vz diff will fit just bear in mind that a diff from a vx and newer will require the accompanying tail shaft OR require getting the yoke replaced with a flange.
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Any VQ to VT IRS duff will also fit. Without having to change anything.
Sent from here, so you can read it there. via iPhone.
Cashman_309
VTII Calais
While this is true. Unless this is a freshly rebuilt diff with higher ratio gears, I wouldn't bother.
Sabbath'
Redblock Jesus
...and this is relevant to his question how?
Cashman_309
VTII Calais
He's looking for a new diff... probably would be best if he got something that will last more than 1000k's before needing a rebuild.
Hence I said 'unless' its been rebuilt, dont bother.
Brett_jjj
Tamworth NSW
vs commodore
Fitting higher diff gears will kill the acceleration, but will drop the engine revs slighly out on the highway at 100 km/h .. Most people fit slightly lower diff gears for better acceleration..
Sabbath'
Redblock Jesus
Same could be said for a VX-VZ diff in regards to a rebuild.. A VQ - VT diff bolts straight up without needing to modify anything.
Whether the diff needs a rebuild wasn't what needed to be answered.
Cashman_309
VTII Calais
Okay hero..
