Wheel Nuts connundrum 12x1.5mm
losh1971
North Tas
VE Series I SS Ute
Do 90s Jeeps run the same size nuts? They came standard with similar centre hub caps.
tantalus
60
VC L
I'd call them centre caps? hahaha ;)
Got your wheel nuts sorted yet?
Found these online
Nice Products in Sydney
vc commodore
Like the Leyland Brothers
VC, VH and VY
They've got the taper for steel wheels, and the shank for the caps.
If the wheel nuts you want are just for holding caps on like you posted up, any commodore steel wheel nut will do...It's the taper that holds it in place, not the length of the wheel nut
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
He wanted the wheel nuts to look pretty ( chrome) to match the centre caps.
vc commodore
VC, VH and VY
That means he can get wheel nuts from anything, except Nissan, Falcon/Mustang and real early Holden....
Problem solved... :)
  • Like
Reactions: Lex
tantalus
60
VC L
I didn't want them to be pretty at all. I'd be happy with rusty looking bastards like the one I posted, but I can't find any. The caps I added the piccy of, were to explain what skull caps are, not the ones that are on the car
tantalus
60
VC L
The nuts hold the wheel on, the shank is a snug fit in the cap, and the corners of the hex on the wheel nut, hold the cap in place. If you use a standard type wheel nut without the shank, you'll crush the cap before the wheel nut gets tight
