commodoredave
VTII v6 no scharge or turbo
the wiring is coming from the loom/harness to the connector (into which connects the o2 sensor wire plug)
the signal wire (its a 2 wire) has a fracture quite close to the connector. The fracture is probably too close to be snipped and crimped. So will need to replace a length of both wires and solder in ( any alternative to soldering?) into a new two pin female connector. Has anyone done this before and are outfits such as jaycar able to supply the electrical parts.
