wortus
- Dec 2, 2009
- 1,885
- 22
- 38
- Location
- Sydney
- VY Series 2 25th Anniversary in Phantom Mica
In all the heavy rain today the back passengers door on my VY sedan has leaked again and there was a lot of water on the floor. It happened about 12 month ago and I removed and resealed the plastic seal behind the door card to the door. This stopped the leak and whenever the car was washed or driven in the rain it did not leak however today in the heavy rain it was parked outside and a fair bit of water got in.
Has anyone had similar issues with their VY's and found a solution? Looking at it there is a lot of water on the door under the door trim, inside the door seal so I think it must be coming out from under the door trim. The drain holes in the door are not blocked and it's just this one door. I'm going to take it apart and check it again and may reseal it again, if anyone has resealed one of these what did you use?
