Hi all, I have just replaced both catalytic converters on my car and found it a whole lot easier if you remove the windshield wipers, the black garnish panel as well.
To do this, remove the skivits around the fresh air intake for the interior air intake, you can change the pollen filter if fitted and clean out any debris and clean the drain hole at the same time.
To do this, With care working from the windshield, get your fingers between the glass and the garnish panel and lift the garnish panel gently up, you will feel where the clips are and with gentle force the panel will lift away, do this all the way along. It's best working from where the two panels join in the centre and working from there to the left hand side of the car.
After removing the garnish panel you can then remove the larger panel and again working from the windshield side you can feel where the clips are and again with care and mild force lift the panel away and off the clips. if you should break some they are not expensive only about .80c each plus GST and the other costs GM put on the part. I replaced all the clips and skivits for under $20.
I know this sounds like a lot of work but found this method really works especially getting to the rear nut on the left hand catalytic converter. As you don't have to use a wobbly to get around the plastic bulge from the fan assembly. You can now use a straight extension bar with a deep 15mm socket (single hex socket is best as this will grab all sides of the nut, Have seen too many rounded off nuts by using multi hex sockets) with ease and undo the rear nut. As one of the members mentioned spraying the nuts with WD40 or any other penetrating lubricant works well.
Put the car on ramps the night before and spray all the nuts and bolts from underneath that need to be undone including the nuts that hold the catalytic converter to the manifold. I hope this method helps others to replace their converters more easily without the frustrations of using a wobbly and getting better torque to getting the bolt undone.
cheers
Mike
