any ideas on a fix for this?
If it’s not a daily and can be off the road for a while, remove the box and strip it down and replace all the worn and broken bits
Start by looking at the following exploded view within the web page below:
www.alltranz.com.au
Check your bank balance before you begin
If in doubt about your ability to do such, go to a gearbox specialist but also check your bank balance…
PS: when auto transmissions fail, ensure that all transmission lines and coolers are fully flushed or better still removal e along with a rebuilt torque converter. Doing such will avoid a new transmission being trashed by crud within the old cooler or old converter making it’s way back to the new transmission.
May also want to have a read of this quick primer on 5L40 issues
The GM 5L40-E is a popular transmission, but it is not without its faults. Here are some of the most common ones.
axleaddict.com
