bjf66
- Apr 11, 2021
- 923
- 1,265
- 93
- Location
- Mt Martha Vic 3934
- VN HDT Aero
approx. 12 months ago purchased one owner low KM VE for missus to use as 2nd car, doenst see a lot of milage
I think she has put up 4000km in 12 months, paid a little bit more than I would have but as it was one owner, low KM, I figured they not making these sedans adn figured less head aches
At the time, of purchase didn't really go into the hole gearbox thing, but now have done a little reading and figured I would replace the trans fluid and filter on 5L40E (M82) early at 52K
The car is performing flawlessly with NO issues, other than there was Bank 2, #1 (pre-CAT) O2 sensor need replacing, which had done by taking out the CAT to replace, however didn't notice any difference in car performance other than fuel consumption was up a little
anyways got the Ryco filter (RTK65) and Castrol Dexron VI ATF ready to go. Will be replacing the Holden VF 6L80E trans filter and ATF as well in next few days
There are NO dipsticks on VE/VF to measure the fluid ...WTF
This is most probably first time the ATF will be changed since new
However I get under car crack the fill plug, which is all good
Looking for drain plug...no drain plug ....now that a bugger ....what were the ZF company thinking, I'm thinking this is going to be a c...t of a job and very messy. I have only stands and ramps, no lift so she is a little tight under there grovelling around
Then decide I'm going to weld bung into trans pan for future ease of changing ATF...although I'm planning not to be changing it every other week
Then googling and see these M82 pans can come with bung as well
So hit the wreckers, manage to find M82 pan with bung, now will change over when I dump the fluid
Had a read up on the changing the trans fluid ....hopefully it will go alright
I changed BMW E39 V8 which had a ZF 4 speed sealed trans a few years back so was going to tackle it same way
post some pic latter
