186565
- Nov 24, 2009
- 16
- 1
- 3
- Location
- Townsville
- VS commodore, vx Berlina
I have a 2004 VY2 CX8 Adventra and I recently had the ABS warning come on intermittently for several weeks and then come on constantly with the orange ABS Light. I plugged my trusty scan tool in and it brought up the C0550 which is pretty much a communication error with the ABS Module. I pulled the offending unit out so I could see the part number (689 389 50725 7) and see if it could be repaired or if I would have to replace.
After some research I found quite a few companies repair these type of units as it is pretty common for the soldered links inside the unit to break. I rang around some of the companies and for around $250 they can pull them apart and resolder them with fairly good results………… except for the adventra or cross 8 units. As soon as I mentioned the 689… number most said they did not have great success with these ones as it is often the processor within it that is cactus and then they are throw away. They are more complicated due to the all-wheel drive and differential braking system.
So my partner rang a heap of wreckers with no success as the units are quite rare and go quickly.
I also scoured the net for second hand or aftermarket but the numbers don’t seem to match anything I could find.
We then rang Holden (and I was glad I was sitting down) gave them the VIN and found that the part was going to cost me about $ 800 from my local Holden parts joint in Townsville. There was only one module listed for that model. They had no stock and would have to order in from Brisbane. I wasn’t real happy with the price and rang the Holden parts place in Brisbane (same mob the local guys order from) and found that I could get it about $ 60 landed cheaper. Good on you local guys – you just lost me as a customer for your mark up.
I ordered the unit and when it arrived I fitted it up and the ABS warning is gone. I didn’t need to erase codes. It has a different number (459261 0 273 004 989 Holden part number - 92148159) so must be one that has superseded the original.
As this was a frustrating few weeks trying to identify the unit and get hold of one I have compiled the following information to assist anyone else trying to sort out their ABS problems.
You need to match the number on your module to the replacement (unless it has been superseded - check with Holden) or you will have issues.
Feel free to correct or add to this list if you want to - it may help someone else.
Model Series Engine Size Notes OE Number (on product)
COMMODORE VT-VX V6 & V8 3.8lt & 5.0lt V8 NO TRACTION CONTROL 0273004219
COMMODORE VT-VX V6 & V8 3.8lt & 5.0lt V8 TRACTION CONTROL 0273004348
COMMODORE VT-VX V8 5.7lt GEN III 0273004389
COMMODORE VY V8 5.7lt GEN III 0273004962
ADVENTRA VY V8 5.7lt GEN III AWD 0273004989 - Replaces 689 389 50725 7 -I am pretty sure this also fits Cross 8
COMMODORE VY V8 5.7lt GEN III 0273004590
COMMODORE VY V8 5.7lt NO TRACTION CONTROL 0273004588
COMMODORE VY V6 3.8lt 0273004589
COMMODORE VZ V6 3.8lt 0265800318
