Rivers56
- Feb 10, 2011
- 93
- 1
- 0
- Location
- Thomastown
- Ve Calais V
Hi all
Recently had a coolant leak (That's now fixed) so I was topping up with water before I fixed it and I accidentally spilled water on the TPS sensor on the side of the throttle body. Soon as I took off out of the drive way I got the code P2127 (Accelaration pedal sensor 2 APP2 signal low voltage). Took it all apart dried it all and it seemed fine for a couple days then came up again. Soon as this code comes up it stops the whole car turns ESP off and puts it into limp mode then after about 10 seconds I can drive again just with reduced power. I replaced the throttle body and sensor with a brand new genuine part and still happened again a few days later. I have then replaced the connector that plugs into the TPS and after 1 day later it happens again. All out of ideas and would be great full for any advice
Regards
Rivers56
Regards
Rivers56
