My eeprom programmers doesnt read 93xxx eeprom, so bought another programmer EZP2019 it read the eeprom but bl**dy cant write, What a luck. I have tech 2 but im worried it wont communucate with acdelco as im sure it a clone. ( it came with a car i bought a while ago )Not sure on VE. Great little tool though. Exploring this fault will take more than a scan tool.
My problem is the BCM, when the old bcm was plugged the car wont turn on and Tech cant communicate with it.They won’t fix it because your problem is easily going to be something else. It could be wiring between the modules or a faulty connector, or any one of the modules or any combination of modules.
I bought one (ilink400au https://www.azscanners.com.au/viden...MIh6mKu8O4-AIVkppmAh3RiQ2QEAAYASAAEgLU0PD_BwE ) for programming vt clusters.Do you know if ilink400AU will do the programming? I posted a video above. I ordered one and supposed to be here tomorrow
It definetly doesnt do VE'S got mine today and was very excited to link the BCM and boom! It doesnt do VE'S programming and the option is not even there. The link of the video is for VZ only. The seller should be more clearer about what this device can or cant do and to what models.I bought one (ilink400au https://www.azscanners.com.au/viden...MIh6mKu8O4-AIVkppmAh3RiQ2QEAAYASAAEgLU0PD_BwE ) for programming vt clusters.
It can't programme vt - vy clusters, but , according to the seller it can programme ve clusters.
It can link modules on vt ve, as far as l'm aware.
If not sure, why not ask the seller first before ordering?
Maybe if your tech 2 can't communicate with the bcm, neither can the i400.It definetly doesnt do VE'S got mine today and was very excited to link the BCM and boom! It doesnt do VE'S programming and the option is not even there. The link of the video is for VZ only. The seller should be more clearer about what this device can or cant do and to what models.
Now Plan B for me is to clone the BCM and see how I go. Hopefully this bloke I know could do it today. Will keep the forum updated.
It definetly the BCM as mentioned in one of my replys when i plugged in the replacement BCM the car started whereas it never used to start with original BCM. Gonna wait and see after the cloning if that didnt fix it then wont bother anymoreMaybe if your tech 2 can't communicate with the bcm, neither can the i400.
So, as @Fu Manchu said earlier its probably a wiring issue?
But now it doesn't start again?It definetly the BCM as mentioned in one of my replys when i plugged in the replacement BCM the car started whereas it never used to start with original BCM. Gonna wait and see after the cloning if that didnt fix it then wont bother anymore
