Skylarking
- Feb 3, 2018
- 10,114
- 10,562
- 113
- Age
- 123
- Location
- Downunder
- Commodore Motorsport Edition
Sorry Nb, must have missed that failed cats were primer for a full on zorst
As to the O2 sensor, 0.0V is either a completely dead sensor (not the case since you swapped sensors and fault didnt move with the sensor) or plug is not pushed in or doesn't make correct contact with the pins or you have a harness issue (open circuit in O2 sensor wire to ECU).
As to engine/trans controller, I always assumed all controllers went through power on self test and if there were issues, a DTC is set. But I don’t think you’ve said a TCM or ECU specific DTC was ever found. Hopefully the new throttle body will sort out the issue (since faulty input = faulty output).
