stooge
- Apr 3, 2014
- 3,157
- 3,097
- 113
- Location
- wa
- Turbo Alpaca
exactly my point when i said you do not understand the systemTake the BCM out of the system and count how many B codes you get!
ZERO
All you will get is U codes because without the BCM B codes will not show.
Go on give it a try before you make outlandish incorrect statements.
Here is a deal if Nev can show me and the rest of the members on the forum this special VF ECU that throws B codes I will ask to have my membership deleted and I will leave forever.
Now that is a deal and a half because there is quite a few members want me gone.
So come on Nev the whole forum is watching now and your PM box will be filling up fast as they all know Nev would never make up a story.
you are just being childish now.
nobody wants you gone and its not a d!ck waving contest, maybe for you it is but it is not that.
it is the simple fact that you know you expressed yourself wrong and are not able to accept the fact that a b code does not mean faulty bcm.
you do not seem to understand that the bcm will issue codes for modules attached to it including the ecu, if the bcm has a mismatch with the ecu it will issue a b code from the bcm because the bcm detected an issue with the ecu.
this is what nev pointed out to you, the bcm issued the code but the problem was the ecu/ecm but you got stuck on stupid over what modules produce what types of codes without considering the fact that some modules produce codes because they are reacting to issues in other modules within the system.
i have said it a number of times now, just because the bcm issued the "b" code it does not mean the bcm is the faulty module, means the bcm has detected it.
a b code can also be issued for a problem with the bcm which is why you need to perform the diagnostic process as outlined by gm.
look at the code at face value...
B101E 46 "Electronic Control Unit" Software Configuration Not Programmed
that does not say "body control module" so what are you going to program?
the bcm or ecu?
or are you going to perform diagnostics on both to work it out before attempting to reprogram anything ?
