VFSV6FORME
- Mar 9, 2016
- 2,603
- 1,273
- 113
- Age
- 74
- Location
- Brisbane
- WN Caprice V 6.0L, VE Anniversity V6 Series 1
I have a good collection of allen Keys and I found two that fit correctly. Now because the exhaust is in the way (Did not drop it by removing the rubbers) I use the Allen key back to front to get around the the pipe itself and the 8 MM (or is it 10MM) Allen key (Unbrako, good quality) twisted a bit when I had the 300 MM Shifter on it. Now by this you an see that the both top and bottom plug are very tight and require no twist to snap it off before you can unscrew it.These are cheap, less than a twenty and may be OK quality, so check out supercheap auto's hex bit socket set.
Otherwise go to Bunnings which has some Craftsman?, Kingchrome, Sidchrome, branded products worth a look at.
I think by using a cheap 3/8 drive with the cut down allen key will snap the 3.8 drive it self and I better to use a genuine 1/2 inch Sidchrome socket that I have that fits the cut down allen key and use a 18 snap bar to get it off. Yes they were both tight doing the other way and if I continued doing it I might have twisted the allen key with the leverage I had with 300 mm shifter.
Just a note, the diff itself was totally dry, not a whiff of oil anywhere.
Question !
Can you jack the rear of the VE/VF via the Diff itself using a typical floor jack. Never done it this way. Never jack the rear or the front via the cross member under the Engine
