Skylarking
- Feb 3, 2018
- 10,125
- 10,583
- 113
- Age
- 123
- Location
- Downunder
- Commodore Motorsport Edition
be careful skylark i orderded the thinnest one ive seen which was linked on here and it still cant really get under the stock front bumper. have to side jack, prop then use the k frame point.Thanks for the heads up @lmoengnr now I have the needed excuse for a better, bigger floor jack
its a very good jack for the price though, 3 ton, 70mm minimum, 550ish maximum for about $180
no but im possibly misremembering. I have ramps for the rear and maybe that angle is the issue to get the jack under the front and the whole car off the ground. saw a couple of wheel jacks cheap(600kg each). be a good idea for a stored car that your working on.Has your ute been lowered? I can get my jack under the front of the Magnum, but it wouldn't go under the front of the Maloo even at stock height.
I bought a pair of steel extension ramps that clip to standard ramps to give the Maloo enough clearance to jack via the front cross member.
Saw on FB that Aeroflo now have low profile plastic ramps that would be suitable for the same thing.
ive got those areoflow ramps now to use as i uset to drive up on a couple pieces of length of 1-1/2" pine wood but every now and then they would skid on the ground, those aeroflow ones look good just high enough to get the big jack under the hsv front barHas your ute been lowered? I can get my jack under the front of the Magnum, but it wouldn't go under the front of the Maloo even at stock height.
Something to consider so again thanks for the heads up.be careful skylark i orderded the thinnest one ive seen which was linked on here and it still cant really get under the stock front bumper. have to side jack, prop then use the k frame point.
Seems like just another reason to dislike long front overhangs in modern cars
