@Daniel Souza, it seems like you had them fixed just the other day... so I‘d be rather angry they fitting injectors which just won’t last for the life of the vehicle...
Regardless, I’d request Holden reimburse you for the Ultra Tune bill. Again having experienced this known injector defect after supposedly corrected just isn’t correct... And having to get UT to fix it because Holden can’t get to it quick enough on a vehicle used for business is also unacceptable.
Then the elephant in the room is when will the 7 other injectors fail and which injectors (either factory or aftermarket) work in our LS3‘s and provide life of vehicle reliability? I’d then expect Holden to fit these to the vehicle as a permanent fix...
I’d also raise this with ACCC & Fair Trading as it’s a defect that requires a permanent fix, not just a fob-off to get you past the factory warranty period.
