was opposite the 520 at idle then the 550 up top and blend to it as long as u done the ECT normal set the 110 to like 80-90 ? ur prob still ok as is but u dont want to delay too much at idle after the EVC has happened, yes u need a wideband to dial in any power or OL, can be scary when the VVE isnt touched as if the MAF and VVE are too far apart (it always references VVE as a check) and it will default to the VVE as its a calculated fueling situation encase the MAF isnt working properly so if the VVE isnt dialed in and it defaults to it then u could be in trouble, sounds good tho its always the little changes no one really does that make the gainsI adjusted the fuel injector boundaries as you mentioned. I went with 550 down low then a blend to the factory default of 520 from 2000rpm up. The idle is more robust and I have more idle torque. I mean that I can now roll down my grass driveway not having to touch the pedal where before I could not do that. Idle rpm and airflow has not changed
