Hey man, only applying changes on 2 tables:- manifold switch open & closed. No harm in pasting to DOD tables, I'll do that next drive.
Another couple of logs needed? I am rich / lean (+/-5%) around the dip so it makes it quite pronounced. I was happy with +/-5% variation as it is a massive improvement on where I was.
I still need to dial in 80-100kPa. I'm picking there isn't much point getting too carried away at the higher MAPS as under normal conditions PE will be enabled.
My wide band turned up the other day. I got the OBDII pass through one you mentioned. Pretty excited to get it in and play. Will install it when the weather clears up (Victoria).
My next mission is to see if I have tip in / out transient fuel issues. I have been reading a lot about it. Check out this log screen snot... Dreaded KR showed up. I'll know for sure once I have the wide band data. BUT, it could be for nothing as this particular log was taken with that sh!t VVE table I had that has the massive taper off that you pointed out to me when you said about re-scaling the MAP axis out to 2 or 3 bar. I haven't done a log with the new VVE table I posted above, it is waiting to go into the car.
