Put a gas thrust block from Opel Astra F hatchback, rose perfectly, the rear door now above, doesn't stir anything to opening
The producer of DELPHI, and it is made in Turkey, somehow directs at doubts. Length more native on 1.5см. Tomorrow the second I will receive and I will establish. In the original died, and there are they much (more than $100 for pair)
Allocated hour for installation of ceiling handles from Opel Senator B, looks not bad. They develop, beige color, their four pieces against three native black colors
As completed an adapter on a propeller shaft. The difference in length of distance between transmission and a rear axle made 4 centimeters. But as similar configuration wasn't put on this car, the necessary propeller shafts don't exist. Didn't begin to cut and weld, decided not to spoil a native propeller shaft. The adapter is made of an integral steel piece, most facilitated, centering and balance the ideal. On the one hand it is put on a native propeller shaft, with another it is inserted into transmission from Opel Senator B R28. The adapter interior from Senator B propeller shaft (a rubber element with the bronze barrel), seal picked up for the size, in an adapter lubricant will be filled.
Restored door locks, painted mandrels, leveled and polished five-copeck coins, touched everything under one key (all locks from different cars)))
Assembled today the heater case under the air conditioner, all joints glued the dense foam rubber cut by long strips, cleaned the remains of being scattered sealing foam rubber with air a door and pasted new taking into account the maximum blanking of a stream.
Slightly undercut a motor noise isolation and it climbed for the engine, finished gluing a heat insulation in front
Threw a wiring in the car, here such brothel it is now created where to put all this I don't know, really there is a lot of it, even taking into account that I cleaned all superfluous, and under a cowl extended a part.
Today I devoted to Opel already the whole evening and night (to garage arrived in 6:00PM, home returned in 10:30AM the next day). The motor wiring almost all is connected, it practically it is not visible, unless over the motor there passes a vein
It should be packed, there was no near at hand an isolation of the necessary diameter. Well and on all certainly it is necessary to stack, braid the rest still etc...
Checked internal light, works, heating of a rear screen too, the pump ABS a current. The starter already twists the engine. And the main thing - the meter panel started to work and something to show!
In the text: "it is called - I am a s*cker, it was necessary to connect the light switch simply... and at once everything became cool. Op! I didn't see it likely since September..."
And because as early as possible I tried all and it showed nothing, brightness control is started on the light switch :yeah:
