Wow - that is just insane. Thats the worst sludge I've seen. Buying a second hand car....you cant exactly pull down the engine and check it ey. But its your car now, your fixing it yourself, and thats a win in my head.
I've had my LLT SV6 since new in 4/10. Done well over and above what the book says in terms of its 15***km oil changes. I done it at 10***km upto 100***km. Now Im at every 5***km now that she's done 160***km.
Oil filter every change.
K&N air filter cleaned and oiled every service
Coolant change every year
Brake fluid change every year
Diff oil every year
Trans fluid change every 2 years
Pwr steering oil every 2 years
Got 2 catch cans with 1/2 inch hoses from both the PCV and CCV. Factory recirc piping is 1/4 inch (I think). So I think and I hope that the larger piping helps it breath a lot better into and from the catch cans. I get about 40ml in the PCV catch can, and just about **** all in the CCV catch can over 2 services.
Have run on 95octane since new.
Out of curiosity I bought a little endoscope camera of amazon ($11) and took a look inside the intake manifold and piston chamber and I'm happy to report, its absolutely squeaky clean, not one piece of carbon on any of the pistons, no oil, **** or sludge in the intake either.
I run a live OBD reader to an old ipod with Car Scanner app. I watch Oil and Coolant temps, intake temps, outside air temp as my primary sensors.
Oil temp sits between 90 - 97 degrees
Coolant temp - 90 - 97 degrees
Intake temps - with in +5 degrees of outside air temp (at speed), can rise to 50+ stationary.
Have set alarms at 105 degrees for oil and coolant. Only time it really gets that high is climbing the freeway at 100kmh in Adelaide hills, **** thats a steep, quick climb. And it still only gets that high when its 38 degrees outside.
I know I have the benefit of having the car since new, so I know exactly what has happened to it.
My opinion, if I WAS buying a second hand car, it wouldn't have 200***km on it. Simply to much margin for error in my opinion. Also if its missed one service, walk away. The only time I'd even consider a car that high Km's, is if it was a full grandpa spec car.
