mohamedelkady
- Feb 21, 2017
- 18
- 1
- 3
- Location
- planet earth
- Commodore VZ
Hello,
Three days ago I noticed some oil leaks under the car in the morning, I checked engine oil level and -unfortunately- it was 1.5 litre less , I added equivelent amount of oil and checked the bottom of the car, it was hard to determine the leak source (The car saffered some leaks year and half before , power steer tank and front crank oil seal and then fixed).
Thanks goddness there are no strange sounds in the engine or smoke out of the exhaust.
I replaced the front crank shaft oilseal yesterday, there is still only one drop or two right under the oil pan after parking.
now I'm considering the oil pan gasket and the oil drain plug. any other places in the engine that may leak oil to check. BTW the rear oilseal was checked and no problem in it.
another question, last 2k km when i changed the oil, it was 1 to 1.5 litre more than engine capacity and I did not care about that, could that what damages the seals and caused the leaks.
Thank you
Thank you
