I always change the filter
fixed the overfilled oil, only 700ml over filled, all is good now, thanks for your help guys!Just did an oil change in my car, drained the oil out, filled up 6.7 Litres (what the manual says). Now the dipstick is reading higher but I’m not 100% sure how much as it is difficult to read.
Should I be concerned?
When you changed the oil, did you change the filter too?fixed the overfilled oil, only 700ml over filled, all is good now, thanks for your help guys!
Yes, I always change a filterWhen you changed the oil, did you change the filter too?
7500k intervals for meThis will start a stir, I leave my Mitsubishi filters on, I change every second oil change, 5000k intervals.
On my BA falcon I used to own I used to do it every second service, 10,000k intervals.
On my VS ute 304 I use the small filter so do it every change at 5000, but if I use the big filter I would leave it every second service.
