If you go back in history on these forums, there's endless posts about oil including some of my own time wasting rants since 2006. Basically the cars have aged, and the oil technology has improved. Manufacturers today aren't expecting today's new cars to last as long as cars from 2000 have. If people were changing over their Holdens like they are with cars today, then they wouldn't be closing down.
The VX's were fist to recommend 10w30 to meet emissions but no one would use it as it did burn at that viscosity. If you have a new or rebuilt motor (rings and pistons, crank) then 5w40 is fine and lowest I would go like HPR Diesel 5 or Shell Helix Ultra is really hard to beat. 15w40 SL/CI4 diesel grade oils are best all rounders and best to clean and keep clean a motor. All the various brand SN rated oils are pretty much the same, but for performance Penrite 10 Tenths 5w50, Valvoline Synpower and Shell Helix are excellent. If you like thicker oils then the Penrite 20w60 in mineral, diesel or full synth is perfect.
Because of how Holden built these motors, the oil will not save you from leaks and the rings will wear regardless over time. I did my first and only rear main around 300,000k's and now has 400,000k's. I owned my car since 60,000k's. The oil will save your bottom end, cam and valve train.
Don't waste your time and money on 5000km oil changes and do in 12 months or 10,000 - 15,000km's. The oils today are not the same as they were even 5 years ago and they last longer due to enviro requirements and service intervals/longer warranties.
