I don't think that's going to work since the door is deadlocked (mechanically). Items below are from the Holden VS Service Manual:
"The deadlock feature provides for mechanical jamming of the door lock actuators. This is achieved electrically via the driver's door key barrel micro-switch."
Checking the Deadlock feature
Open all windows.
Close all doors.
Actuate the deadlock feature from the RHF door with the key.
Check that all door lock buttons cannot be pulled up. They are electrically blocked.
NOTE: The front door lock (snib) buttons can be pulled up slightly, but they will be under tension.
One thing you could try is to disconnect and reconnect the battery.
Deadlock
The deadlocking feature applies to all four doors, but not to the luggage compartment lid or tailgate. After the deadlocking feature device has been engaged, unlocking is only possible at the RHF door from outside, with the key. To ensure access to the vehicle if the electrical system should fail (discharged battery), after the system has been engaged, the deadlocking feature is mechanically actuated for the RHF door, and electrically for the other doors.
