greenfoam
- Jan 13, 2005
- 7,902
- 128
- 0
- Age
- 102
- VP Executive R-spec
this is by far the best original test mod i have seen in ages...pity you didnt carry it out before you did the heads Foamy it would have been very interesting to see its true value...in racing 1 psi in a tyre can make a difference so in theory that should also be the case with air intake temps...
Ah you are confuzzled, the heads are stock for the moment, nothing has changed apart from the camshaft/balancer and timing chain as of yet :0. I have no way to back to back test the temp drop from the sheild but there will be something in it. All engine master winners use one and the American engines don't even have an exposed camshaft like the Holden V8 does. Those guys are using them for heat refelection only, on the Holden it also stops the oil washing onto the manifolds base so it's double win. Pity we can't have a camera in there to see just how much oil we are talking about but seeing how much sludge can collect under the manifold and in the valley and in every single mm of both, we can assume it's alot and it must be a very fine constant mist, so I wont be able to stop all of it. But 95% of it will be better than nothing. This mist of oil is @ around 100 C so it's pretty nasty. I'd rather have my hand above the sheild than below it
