so i will address your issues, 1 at a time:
I agree that the parcel shelf has a role to play but at the same time cannot see how a couple of cm's will have any notable affect on it's strength at all (and my opinion is that there is very little strength there anyway!).
so i am safe to assume that your opinion is based on the many years spent at university studying engineering?
This car is also on straight gas with big beams securing the tank to the car; I cannot comprehend how a tester could believe this car is now unsafe.
the "big straps" you are talking about work as an X-frame and support the 2 quarter panels, roof and rear windscreen? are you saying that having two strips of 30mmx2mm steel bolted to the FLOOR of the boot with 4 bolts will somehow perform the same function as a parcel shelf?
Especially when an engineer listed on Vicroads agrees.
agrees, and yet wont give you a cert....
Surely if this problem arises this much and an engineer is so adamant it is not a problem then Vicroads requirements are overkill and should be amended to provide further guidance than simply any modification at all requires an expensive engineers cert. Talk about expensive red tape.
see, here's the thing. it arises so much because so many people have chopped their parcel shelf over the last 20 years (instead of using speaker spacers) that its become a a pain in the rectum for most RWC assesors. everyone is like: ooooh its only 2cm its no probelm.. when in reality, it IS a problem. so much so that RWC inspectors are required to check and fail if they find the modification has been performed.
ps whilst speaking of structual integrity I jacked the car up last night and put the front on jackstands and when lowering the jack I had forgotten how much flex is in the chassis the front drooped down notably and the doors were difficult to open! In a car this weak I find it a farce a couple of cm on the parcel shelf matters.
wait till you see what happens in an 80kmph smash
Oh and I happen to be a cyclist too and have lost count of the number of ppl who have carelessly nearly run me over. If Vicroads were so concerned about road safety i think they have totally misjudged the problem here!
no idea what this means.
anyyyyway, try taking to another RWC tester.
