UPDATE!
The transmission fell off the jack and nearly crushed my wrist while i was trying to get it back in, took me another fall and 3 hours to get it back in the car. THE DOG. is in.
How did it come out so smoothly I dunno ay...
Steering working great, located my cancelling cam and copper ring but the cancelling cam misses the bit of plastic that sticks out of the indicator somehow.
Found a bent pushrod???? don't know what cyl it was from, lost another so I grabbed 2 from a series 2 buick at u-pull
Heads reinstalled and sequenced (90nm/90degrees + 90 degrees again) with new gaskets and bolts.
One of the gaskets split downwards from the front drivers block dowel but not into any other channels so hopefully no leak on cylinder 2...
obviously a poor hole size from the gasket makers.
Intake reinstalled (new intake beautiful condition $50 with injectors) and rockers all on. Scored the passenger side alloy rocker cover from a u-pull VN series 1 so i am hoping to go get the other tomorrow since I didn't have a ratchet at the time and only brought my impact gun.
So obviously it didn't fit on the last rocker bolt next to the brake booster. Lost my 3/8th socket as well so need to look for that tomorrow on the same car.
Tomorrow will consist of new injector hose because i had a fuel leak last time, bunnings trip for a 3 piece (t piece) pipe connector to combine the breather from the alloy rocker cover and the series 2 PCV hose into the intake, hooking hoses and wires back up and getting the other rocker cover.
Then I'll comp test it to see if we are all good and after that we are just waiting on the radiator and she's good to go!
And putting back the tailshaft. arms will be hurting on that one above my head for 15 minutes with those stupid rounding 15mm locking nuts and no ratchet.
New windscreen is in and looking mint.
EDIT: engine turns over perfectly by ratchet
