bridge 5 &6 at the OBD plug, top count the top row 5 and 6 from the left then count the engine light flashers by turning the key to on not start. First flashes are tens with a break followed by fast flashing which is 1-9.Don't have access to a scan tool and no engine light.
So it does this without the serpentine belt and the AC on? AFAIK the car is supposed to increase the idle when the AC is on, so could lean towards fuel starvation again, but I didn't thnk it would count for that much.Also if you turn the A/C off the problem is virtually non-existent but that is not an option on 38-42 degree days.
Won't show a code other than 12 if there's no persistent engine light when the car is running.bridge 5 &6 at the OBD plug, top count the top row 5 and 6 from the left then count the engine light flashers by turning the key to on not start. First flashes are tens with a break followed by fast flashing which is 1-9.
I'm not sure wtf it's doing tbh.So it does this without the serpentine belt and the AC on? AFAIK the car is supposed to increase the idle when the AC is on, so could lean towards fuel starvation again, but I didn't thnk it would count for that much.
I'm sure if you go over what you removed you will work it out, I'm sure there a earth lead under the compressor, check the wiring.I'm not sure wtf it's doing tbh.
When i took the serpentine belt off and had the A/C on it still had the problem. Didn't try it with the A/C off.
Thinking i forgot a ground wire somewhere on the A/C or something.
Either that or the DFI/coils
I should have said the fuel lines run close to the back of the intake manifold.I'm not sure wtf it's doing tbh.
The earth is likely to be in that conduit at the bottom, still wouldn't hurt to try running some extras if you've got some wire around.I swear right here around this bolt there was an earth but i fuckin CANNOT find it and the engine is red hot at the minute.
