[SOLVED] VT ecotec about to explosively-self-disassemble
losh1971
North Tas
VE Series I SS Ute
Throw on a SH coil on would be the next thing I'd try given one is damaged.
losh1971
North Tas
VE Series I SS Ute
My thoughts on that, if the coil is cactus, it possibly f#cked the dfi?
Well yes that's what happened to mine.
  • Like
Reactions: Lex
Sandst4rm
South Australia
VT S1 Calais Ecotec - VP Ute 3800
I'll see if i can test it with a DFI and coil set from a mates ride and if that fixes it I'll be saving for a new set.
Probably go with GOSS from supercheap or something for $250 unless anyone has a better idea.
Cheers for the help lads, think I'll take a break for just a little bit on this one.
losh1971
North Tas
VE Series I SS Ute
SH from wrecker DFI is the go. Aftermarket are junk and OEM are close to $400. Mace coils or SH set are ok too.
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
I'll second the wreckers. Dfi & coils.
Bay 13
Dandy
VT.
Maybe search on Marketplace on facebook for a set as well.
losh1971
North Tas
VE Series I SS Ute
I have 6 or 7 coils, which are going in the last parts pile to be sold off cheap to clean up my shed. I'd give you one but freight alone would cost more than one from UPI.
Sandst4rm
South Australia
Yeah righto u-pull trip it is after I test the DFI then.
Thanks lads!
  • Like
Reactions: Lex
H
harrop.senator
Guest
Am I the only one that thinks it sounds dead? Its got metallic on metallic noise has a bad miss and sounds like woody the wood pecker on throttle.
Last three times I've heard this noise was usually after skids and attempting to drive home.
Have tried to hold it flat to see what comes flying out on each one but always seems to just get to the point it'll stall and not make a show.
Here is an Ecotec with quite a violent woody .
https://hosting.photobucket.com/albums/rr73/skitzone/20170716_072901_zpsqlkdpyua.mp4
