Tailshaft coupling/gearbox seal
Glaze
NSW
VT
Hey guys I’ll be changing the tailshaft coupling soon behind the gearbox, the one at the diff looks okay but may as well change it while it’s out.
I heard genuine are the best to go but I have a kelpro one sitting in the garage was wondering if I should use that as well, if anyone has had experience using kelpro would like to know.
It also seems like the gearbox seal to the tailshaft is leaking, has anyone changed this before, if so how to do?
Thanks
losh1971
North Tas
VE Series I SS Ute
I have Kelpro and they are fine. If you're replacing the box end one then replace the rear one too as it tends to take more load than the front as it deals with the flexing of the diff.
losh1971
North Tas
VE Series I SS Ute
What happened to the coupling, looks like something got wrapped up on it?
  • Like
Reactions: Lex
Immortality
Staff member
Sth Auck, NZ
HSV VS Senator, VT s2 Exec, VX Calais II L67
That's probably original, @losh1971 take note of the little arrow on the rubber coupling :)
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
I thought the arrow was supposed to point to the front of the car? Thats pointing to the rear.
losh1971
North Tas
VE Series I SS Ute
According to the manual the arrows are supposed to point towards the heads of the bolts.
Immortality
Staff member
Sth Auck, NZ
It points towards the flange.
losh1971
North Tas
VE Series I SS Ute
