I'm going to someone other than who did the last alignment, because apparently the person who did our last alignment did it with their eyes closed.
So I go to get my wheel rotation and balance today, and they call - where's the lock nut key ?
I said it doesn't have any.
Yes if fuc.ing does.
As second owner, car arrived with lock nut thing in glovebox. I looked at the wheels and couldn't see any difference - little did i know that the lock nuts have a screw on cover that disguises them.
Anyway, during a spring clean at home, i think it was thrown out.
The dealer last week during a service was meant to rotate. Did not. And didn't mention anything. Do they carry some sort of master tool or key? Im sure im not the first ******** to lose their key
The dealers dont rotate them alot of the time because they just try and smash as many vehicles through a day to turn profits so alot of what they are supposed to do does not get done.
Most of them just do oil and filters most of the time.
Also is there any reason you are getting a balance?
Once they are balanced they are normally good for the life of the tyre unless a weight manages to fly off.
Thanks !There is about 6 or 7 different key patterns per lock nut key manufacturer.
You are able to buy lock nut removers, which grab on the side of the wheel nut and undo it....Only problem is, it stuffs the lock nut, which requires replacement.
Another way I remove them, is punch an 18MM socket over the lock nut and undo it, via a breaker bar...Again, it stuffs the locknut, but it is still effective
The other option is, most tyre shops and possibly dealerships, have a "collection" of lock nut keys....It might be worthwhile calling into a few and see if you get lucky enough to find the correct one.
Finally, if you have to replace the lock nuts, with others, take note of the brand and the number on the lock nut key for future reference..If it happens to get lost, you are able to order another locknut key and save you the headache you are going through at the moment
Thanks I will start saving for new tyres they are about 7 years old but I don't do I lot of k's as I use too. I give Mycar a look, I got these tyres from B-Jane and 1 month later got a nail it the edge and couldn't be repaired cost me another 110 for a tyre so they wouldn't take care of me so never went back to them.
And yes to the gauge its my own, I tested it with the Servo digital one and it was correct so they lower the wheels to 36PSI every time.
