V6 Crankshaft Info
chrisdoesitbetter
| → ³8°º™ ← |
VR 3.8L
i know it may sound like im repeating a question but ive read several posts with conflictiing answers. i have a series 1 VN with all manual conversion parts. i have a VR that i want to trans plant it into if i understand correctly, the Vr had the 8 bolt flywheel, therefore will the T5 bolt straigh in? can someone that has done this tell me staright up?
OZ38
62
Jurien Bay WA
VS L67 T5 SDN & VY V6 M35 UTE
I could stand to be corrected here but, I believe if the VR doesn't have a Ecotec engine in it (from a transplant or whatever) then it will have the same bolt pattern (6 bolt) on the manual crank as the Series 1 VN V6 manual ?
Anyone confirm if I'm right or wrong ?
Deek
OZ38
62
Jurien Bay WA
Deek
Ok I done some more reading a i think the VN / VP T5 had a 6 bolt flywheel & then maybe the VR T5 got changed to a 8 bolt flywheel. Then the VS T5 also got a 8 bolt flywheel but has a different mass balance to the VR Flywheel.
Deek
383 hatch
41
Cowes, Phillip Island
Deek, if you read the first post it will tell you. VN Series 1 is the only V6 with the 6 bolt pattern (both auto & manual, just different patterns). From VN series 2 onwards all V6's use the same 8 bolt pattern (including Ecotecs).
OZ38
62
Jurien Bay WA
Thanks Tim,
Yeah sorry for being lazy as I should have gone back to the start for the correct info.
Deek
vpcalais6
F#%ING [P] PLATER
central coast
www.myspace.com
V6 manual vp Calais
Hey mate because the vp s2 and the ecotec share the same bolt pattern does that mean I can use a ecotec flywheel on my vp s2 for my manual conversion
OZ38
62
Jurien Bay WA
Not a 100% on this because they are different engines whether the balance of the flywheels would be different. But for my way of thinking the heavier mass of the later ecotec flywheel maybe of benefit to the VP engines balance.
Deek
vpcalais6
F#%ING [P] PLATER
central coast
www.myspace.com
V6 manual vp Calais
Would I be able to get it balanced the same as my flex plate and do you have any idea of where I can get one
Thanks
