Which one did you have the pleasure of replacing? I removed them all one by one over a few weekends to try and figure out what the hell was going on.
Of course the recirc door actuator was the hardest one to get at so it was the last one I removed. When the shattered bits of gear fell out I knew what was going on. Then I had to leave my car in pieces for a couple of weeks until the new recir door turned up.
Removing the whole fan plenum is a massive job just to replace the recirc door and it could have been entirely avoided if Holden had made the bulkhead opening about an inch wider. If they would have done that you could replace the recirc door from the front by just removing the cabin filter holder.
I only ever looked at and thought about replacing the driver side one
It's fixed temperature issues, direction issues and stopped the fan from randomly going full blast to low or anything in between
About 3-4 years ago I had holden look at it twice and they just palmed me off and did nothing, while still charging a decent amount. The literally wrote on the service notes that it was user error selecting the wrong vent direction settings...
I didn't find the screws that hard to get in and out, as I used a 300mm felxible extension drill bit
I found it ridiculously hard to line up and insert the arm into the actuator at the right angle and then line up the screw holes
