VFSV6FORME
- Mar 9, 2016
- 2,603
- 1,273
- 113
- Age
- 74
- Location
- Brisbane
- WN Caprice V 6.0L, VE Anniversity V6 Series 1
EEEK!. that's another strange issue you have possibly stranger than no air on your face when you select it.Just wondering if anyone knows why my a/c fan doesn’t work however will occasionally work but will only blow very lightly even with fan setting on full.
Sometimes if it has been working, after I turn the car off and take the keys out air seems to still be blowing out the vents..
Haven’t tried with the heater but the air coming out of the a/c definitely is cold..
Will replacing the HVAC fix this?
You could replace the HVAC Module but I think all these strange issue are coming from deeper in the car like the BCM
The HVAC Module does control the Fan speeds as it has a BIG Heatsink with large fins on the rear that goes into the air duct for cooling.
Now if you buy a Second Hand HVAC try to match all the Specs to be the same as your one. Is you car a single Zone or dual Zone? What VE do you have, Omega SV6, SS or other.
This issue that I have that has No air on the Face vents now and then I found the same issue with a WM 2012 Series 2 caprice and to get around on the Caprice leave the VENTS set at foot before turning the car off, then start the car, turn the air on, then select the face and all is GOOD. It does not care if the Vents are controlled by a Manual selector or a touch button.
