brian church
Hi My Vf has 6500ks now on the clock oil was changed at 2800 I have noted oil is down to just below the crosshatched mark but the manual indicates the low mark is the next hole below does this sound correct?
Has anyone else noted oil use like this?
and the lifter tick noise is apparent in mine worse when hot is this acceptable? I took it back to the dealer after the first service/oil change they said its normal typical
