The LSA and GTS TR6060 is the close ratio manual and that's mint with 3.7's. 1st and 2nd is taller, less gappy into 3rd and 5th and 6th is 0.83:1 and at 100kmph in 6th, they're around 1750rpm like the LS3 auto. The NA HSV manuals are the same ratio as the stock VE/VF. The HSV close ratio box is the same ratio as the VZ V8's from 1st to 4th with a lower 5th and 6th. I don't know why Holden changed to the gappy ratios in VE, makes no sense!
Here's a tool I made up a few years ago to get 5th and 6th gear off and swap them for the lower GTS ratios.
