OK, took the car for a run, purrs like a lion (extractors and 2/34" exhaust system) anyhow, it would change into second at about 40km/h revving at 4K. My son has a stallie in his VY and the VP appears to react the same way. He said it is as if the VP has the power switch is on (it doesn't have one) When the VP was a manual we never had to drive it this hard for gear changes (never did) Also the kick down did not work, should there be a little tension on the cable at the throttle or should it be loose. Another also I haven't been able to find out anything about a plug just forward of the speed sender on the gearbox, I have also adjusted the shift linkage to gearbox so that there is no play( should there be some play?) And it does not run sluggish.
