The ballasts were just connected to battery. They are out now. So battery>ballast>wire to globe and wire to existing driver side globe plug. Passenger side globe plug had 2 prongs from a spot light plugged into it. This is where it is black as if burnt out. I'll do the pics when I can.What I'm trying to determine is how they powered the ballasts and whether they hacked and tapped or just plugged a spade terminal into your existing plugs.
I'm not sure if it is a spot light. I just called it that but I think it is called a bar light? I just tried to upload photos but they are saying they are too big. I'm not sure how to show you. We installed a new blinker about a month ago and it is blown. Put in headlights and only the left is working. The one on the side where the blinker blew isn't working. That is where it is all black from that bar light.You're fortunate that driving a spotlight on the existing loom without additional cabling and relays didn't burn out your switch, had there been two spotties it may have.
