Trevor loves holden.
- Jun 6, 2019
- 3,508
- 750
- 113
- Location
- Victoria
- vs commodore
I would start by testing fuel rail pressure and testing for spark by removing a plug lead and pulling a plug or if you have a spare lean the plug on its nut on the engine block then crank to see if spark is present. I think your better off stating ever think you have done so far and paint a picture because your all over the place.What do you think is causing this sort of struggle start? I’m beginning to think it’s back to fuel I’ll check the plugs as well
List can be endless. DFI, coils, CAS, dfi plug or wires to bcm, fuse or relays.
Fuel pump, fuel filter, injector pulse wire from dfi. BCM security staying on.
