Zacoldfield
27
VY SS
Don’t know much about cars so that’s why I’m here asking for some opinions. Link below showing the car trying to turn over but just miss firing
Thank you
VT2Commie
WA
VT2 Clubsport R8
Sounds like a fuel pressure problem.
Get a fuel pressure gauge and connect it to the fuel rail test point and check what the pressure is at key on, Pull the fuel pump fuse and/or relay and crank it over for five seconds, turn the ignition off, then connect the pressure gauge, then put the fuse/relay back in, or fuel could spurt out in your eyes.
Should have 380-440 Kpa fuel pressure with the ignition on engine off. cycle the ignition on and off 3 or 4 times and see what the pressure gets to.
See how you go
Or take it too a shop.
