VZ v6 engine mounts replacement
sirjolly18
Bathurst
2004 holden VZ v6 ute.
My 2004 engine mounts need replacing but the mechanic at utlra tune said it would cost $350 labour to fix.
I bought some new mounts from supercheap for $127 but was wondering what needs to be done to replace them yourself? And is it as hard to do as the vs v6?
charliebrown069
VZ SV6
Did you end uo doing this. As i am about to do mine in the near future.
andyman
The Only 6sp VZ Wagon
34
Orange, NSW
2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
depends on what side of the motor its on... drivers side isn't to bad.... passenger side is a bit harder.. the a/c compressor is in the way a bit
Hrd455
35
Vz v6 ute
Drivers side is a pain if u have abs, i found that passenger side was easier
