The91kwbeast
- Jun 12, 2022
- 164
- 89
- 28
- Age
- 36
- Location
- Sydney
- VF Calais V
De-pin the plugs, taking note of wiring layout (take a photo) Lift the butyl tape on the floor of the boot (silver foil backed tape) close to the battery it covers a hole, feed both sets of wiring through the hole, neatly run 1 set across to the drivers side bi-modal re-pin the plugs and connect. 10-15 mins or so, I found it to be quite a simple job but think i extended some wiring from memory it was a while ago.
Thanks but there is no tape on the passenger side close to the battery. Spoke to the owner and he's suggesting to drill a hole in my spare wheel well.... So it's literally drilling into the car or removing the battery assembly and wiring for the passenger side.
And then I need to de crimp the drivers side since it doesn't fit into the hole provided there either.
Good times..
