Another VE Timing Chain Post :/
tml678
2017 HSV30 Senator, 2002 Corolla..
Do you need to bump three old threads on the same topic asking the same question..?
Razaali
34
Holden Sv6 2007
Hi I have Ve sv6 2007 I just bought it and showing me p0101 error and check engine light and Stability control light Automatic turn on and off .
Tamara Lee
40
Vu ute holden
  1. My Ve 2010 just started running rough not firing all cyclinders plus the safe mode comes on n tells me to check engine for awhile on and off. on top its just chewing my fuel coming out raw as. Theres a shocking rattle that was there wen i would more turn to the left but now it as soon as its on n if i kick it over the smoke that is belowing from exhaust if phenomenal? Any one know what could be ?
  2. How hard is timing chain to change in 2010 SIDI V6 VE ?
Codes are saying multiple misfiring in cyclinders misfir cyclinder 5
O2 sencor check engine light constantly stays on and then it will flash safe mode activated
redvxr8clubby
Sunshine Coast QLD
VX Clubsport R8 & VE SS
  1. My Ve 2010 just started running rough nit firing all cyclinders plus the safe mode comes on n tells me to check engine for awhile on top its just chewing my fuel coming out raw as. Any one know what could be ?
Codes are saying multiple misfiring cyclinder 5
O2 sencor
Misfire on cylinder 5, considering it's specific cylinder, perhaps just spark plug or coil. Before buying new replacements try swapping spark plug or coil with another cylinder (one at a time) and see if error moves to other cylinder. O2 sensor, is there indication as to which one, front or back, left or right. I believe there's four of them.
Tamara Lee
40
Vu ute holden
Thanks, shall do first ive edited whats going on if you have n other knowledge that woild help me id greatly appreciate.
Scott Castles
Glenmore Park
2012 commodore ute series 2 manual
yes i have exactly the same a damn rattle when i turn left but can not find the rattle at all.
Also my VE sidi is also running super rough, changed coils and plugs, cleaned MAF sensor with correct cleaner, now its showing bank 1 and bank 2 sensor
