delcowizzid
on holiday
Check you lifter preload properly.pick a cylinder and turn the engine un till the exhaust valve on that cylinder just starts to open.release the bolt on the inlet valve on that cylinder and let the lifter relax for a couple of minutes.then turn the bolt down till you get to 0 lash and the pushrods gets a little drag when turning it between your fingers then measure how many turns you get on the bolt till tight.turn the engine un till the inlet valve is just about to close and do the same procedure on the exhaust rocker bolt as you did on the exhaust. Let us know how many turns you get
