EricSSV
- Jun 18, 2022
- 187
- 197
- 43
- Location
- Melbourne
- VF SSV Sedan Man
I have thought about some of these things but wasn't sure about the on road use and tyre wear etc.That's ok with good pads, now you can use 18" wheels and R-spec tyres and will make a dramatic "blow your mind" difference over any road tyres! Run as much negative camber on the front as you can with 2 to 4mm toe out and take the rear sway bar off. With coil overs, raise the rear suspension height to reduce understeer or lower the front. Big sway bars on the track will screw the handling potential up, just use the stock front bar and balance the car with ride height adjustment and watch your lap times and confidence in the car improve!
Its a weekender and it will be driven to the track.
I do sometimes daydream about and SS just setup for this (i dont see it happening)
